vcIntListProperty
Typed property that holds a list of values.
Parent: vcProperty
TypevcListPropertyTypeRGets the property type.
Valuelist[Integer]RWGets or sets the property value.
waitForobjectList[Integer] OR None value,
waitForNotobjectList[Integer] OR None value,
